How to Isolate Fiber Port Traffic
jeremy.venlet
We would like to setup a link to our DR site that is separate from our main network traffic.  This link will be used by an EMC VNX SAN for replication traffic.  The SAN will be plugged into a fiber port on a 3750 switch and going out from the same switch (going in as multimode, going out as single mode) into a patch panel that runs over to the DR site (about a mile away).  At the DR site it will go from the fiber panel into another 3750 switch which ends up going back out of that switch into our DR SAN.
I'm wondering what the best way would be to configure the fiber ports to accomplish this.  I'm affraid that the replication traffic will find it's way over through another route and congest our main network unless configured appropriately.
Jeremy
Giuseppe Larosa
Hello Jeremy,
you can use a VRF to build a logically separated routing table on the C3750 boxes
you will have the involved interfaces associated to the VRF, and the traffic will be kept isolated from the rest of the network.
ip vrf SAN
rd 100:100
interface x/y
ip vrf forwarding SAN
! you need to reconfigure the IP address
ip address 192.168.1.1 255.255.255.252
see
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/31sga/configuration/guide/vrf.html
Hope to help
Giuseppe
Giuseppe Larosa
Hello Jeremy,
ip vrf SAN
rd 100:100
interface x/y
see
Hope to help
Giuseppe
Thanks so much for your reply.  I've never used VRF's before, I'll take a look into the guide.  We do have our own private fiber from our main site to the DR site.  Would there be a way to use VLAN's to do this?
Jeremy
Hello Jeremy,
VRF lite actually means using per VRF Vlans on L2 trunks, so the answer is yes, you will add a Vlan X on the link between main site and DR site and the SVI of that Vlan X will be associated to the VRF on the C3750 devices.
You may need also static routes in VRF to route between the sites
something like
ip route vrf SAN 10.10.10.0 255.255.255.0  vlanX
Hope to help
Giuseppe
Great, thanks for expanding on that.  I appreciate your help!
Jeremy
