how to limit bandwidth on nexus 9ks
Deepakmanne7890
HI all ,
As we did bandwidth control on cisco routers and we are willing to do same for 9ks , i would like to know the configs to implement same on 9ks :
below are the configs we add on router :
class-map match-any TINA-DATA
match access-group name TINA
policy-map POLICE-TINA-INET
class TINA-DATA
police cir 300000000 conform-action transmit exceed-action drop violate-action drop
thank you
will above configs work with 9k as well ?
Usually, the QOS config is not the same across different platforms. So, come commands may work and some may not. You would have to refer to the config guide.
HI reza ,
thanks for your reply , i have tried different combinations but no luck , am looking for exact configs that works on 9ks .
