How to load configuration using Cisco USB port???
Egor Khomenko
on USB-flush configuration there. I try to download it gives this:
Switch#copy usbflash0: 3560-ST
Source filename [3560-st]?
Destination filename [3560-ST]?
%Error opening usbflash0:3560-st (File not found)
What is the Problem? flash formatted on most Cisco (it has decreased in numbers from 16 GB to 2.75 GB)???
Collin Clark
If you are copying the config from USB to the running config-
copy usbflash0:conf-file-name running-config
If you want to copy the running config to USB-
copy running-config usbflash0:
5 Replies 5
chandra_rc16
Level 4
Level 4
Hope this helps.
copy usbflash0:filename.txt
Chandu
Regards, Chandu
Syntax is the one as Chandu poined out.
However, i see there is a space between usb0: and the filename.
"Switch#copy usbflash0: 3560-ST"
Make sure there is no space in the syntax above and also the file name is correct.
Thank you so much. It would seem a trifle. But, I had a little brain naprech. It is a trifle, which I came twice
Collin Clark
Depending on the model, the internal flash may allready be refernced with usbflash0
If so the external USB may be usbflash1
