How to monitoring TCAM usage on 3750E?
CSOCO10744245
Hi team,
I need a help.
I had a lot of problems with TCAM table in the past and made changes in SDM ended whit that. But now want to be proactive and anticipate the problems in my TCAM table.
Ie: If the my template is "default desktop" they support a number of indirect IPv4 routes of 2k. I wanna know automatically by my management tools if this number reaches 1.9k.
That way I can take corrective actions before the problems starts on my network. So my drama is:
How to monitoring TCAM usage on 3750E? Is possible to enable traps? I found this MIB ciscoSwitchHardwareCapacityMIB. It will work?
http://tools.cisco.com/Support/SNMP/do/BrowseOID.do?local=en&translate=Translate&objectInput=1.3.6.1.4.1.9.9.663
PS: All my WS-C3750E-24TD have the following IOSs Version 12.2(52)SE2 and Version 12.2(44)SE2
Tks
Bulgarelli
2 Accepted Solutions
Peter Paluch
I do not know if there is a SNMP object available for the TCAM monitoring (I am not saying it does not exist, neither). What can be used is the show platform tcam utilization that could help you see if any feature in the TCAM is close to the available limit.
Best regards,
Peter
Hi Bulgrelli,
CISCO-MAC-NOTIFICATION MIB should do the trick (OID cmnUtilizationUtilization 1.3.6.1.4.1.9.9.215.1.4.5.1.2)
the trap to use is
- cmnMacThresholdExceedNotif:
This notification is generated when cmnUtilizationUtilization exceeds or equals to the
cmnMACThresholdLimit for a given entPhysicalIndex.
before doing the snmpwalk configure
"mac address-table notification threshold" CLI on global config mode
Riccardo
5 Replies 5
Peter Paluch
Best regards,
Peter
Hi Peter!
I Know the command show platform tcam utilization. I used it a lot.
But now want to be proactive and anticipate the problems in my TCAM table. So I need to use somenthing like traps or SNMP management.
Bulgarelli
Hi Bulgrelli,
the trap to use is
Riccardo
Hi Riccardo.
It seems to solve part of the problem because only the number of unicast mac addresses will be verify.
Thanks!
Bulgarelli
Hi Bulgarelli,
yes indeed that OID can only monitor unicast mac address but as far as I know this is the only thing you can check via SNMP (as far as TCAM is concerned).
Riccardo
