High Cpu on Cisco 500 switch
davidmalan
We are seeing the cpu on 2 of our C500 switches running at 99% with the following process causing the issue, have anyone seen this before:
84      165202     50170       3292  0.00%  0.05%  0.05%   0 HQM Stack Proces
  85   167864326  14974841      11209 64.00% 63.24% 63.39%   0 HRPC qos request
  86           0         1          0  0.00%  0.00%  0.00%   0 HRPC span reques
David
Somasundaram Jayaraman
Hi David,
++ The "HRPC Qos request" happens every time cli needs to be rewritten due to a QoS  change; CoS value, DSCP value....  IE: when you change the port role from Desktop to Pesktop+Phone this happens.
++ Could you please confirm whether DHCP snooping is enabled on the device? If so then could you please disable it by issuing the command "no ip dhcp snooping" on the switch and then monitor in order to check if it resolves the issue.
++ In the newer IOS versions i believe there is an option to disable dhcp snooping permanently.
Hope this answers your questions.
Cheers
Somu
P.S : Rate useful posts
