How to put router in trunk mode and link to switch [Solved]
nasdriver
The idea is to configure the wifi on the C870 router.
So, I have this switch prepared to receive the router on one port with vlan 109.
The router is with c870-advipservicesk9-mz.124-24.T2.bin
The router is connected from f4 to the switch port, but when I try to put the router port on trunk its not accepting the switchport mode trunk
interface FastEthernet4
description secondary-TO_SW
no ip address
duplex auto
speed 100
no cdp enable
interface Vlan109
ip address 192.168.71.4 255.255.255.0
ip default-gateway 192.168.71.1
interface Dot11Radio0
no ip address
encryption vlan 10 mode ciphers tkip
broadcast-key vlan 10 change 45
Any idea?
** the router its not accepting the switchport command once Im inside the interface
No it is the subinterface that you should associate with the VLAN (and which you already have associated with the VLAN). You do not need the switchport mode trunk and it does not work on the interface (as you have discovered). You achieved the same result of this command when you configured
interface fastEthernet 4.109
encapsulation dot1Q 109
now what you need to do is to remove interface vlan 109 from the configuration and to configure the IP address under the subinterface.
Rick
Rick
11 Replies 11
usasigcis
yeah it wont work because it is a router not a switch. so you just need to tag the dot1q with the correct encapsulation id to your subinterface;
in your example it 109
interface FastEthernet4.109
and this is the result.
R(config)#interface fastEthernet 4.109
R(config-subif)#encapsulation dot1
R(config-subif)#encapsulation dot1Q 109
R(config-subif)#exit
R(config)#int fastEthernet 4
R(config-if)#switchport mode trunk
% Invalid input detected at '^' marker.
its the phisical interface that I should associate witht the vlan, right?
yeah thats normal. you dont need to run switchport mode nor it will work.
just do no shut on the physical interface.  and print "show ip int br"
this is what I have
R#sh ip int br
Interface                  IP-Address      OK? Method Status                Protocol
Dot11Radio0                unassigned      YES NVRAM  reset                 down
FastEthernet0              unassigned      YES unset  administratively down down
FastEthernet1              unassigned      YES unset  administratively down down
FastEthernet2              unassigned      YES unset  administratively down down
FastEthernet3              unassigned      YES unset  administratively down down
FastEthernet4              unassigned      YES manual up                    up
FastEthernet4.109          unassigned      YES unset  up                    up
Vlan1                      unassigned      YES NVRAM  administratively down down
Vlan109                    192.168.71.4    YES manual up                    down
apply the ip address under the sub interface
so '
no int vlan 109
int f4/109
Rick
Rick
nice!
can reach the default gateway already,
can see the router on the switch arp
but can't go outside
Will check further on the switch and find why
see if you have a reverse route from the outside router to R
can see the ip configured on the router, but can't ping it.
The switch port interface config:
interface FastEthernet0/19
description ToWifiRouter
switchport trunk allowed vlan 109
i presume the other side is a switch
what is the below results;
sh ip int br | ex unas
sh span vlan 109
sh int trun
sh ip protocol
sh ip route
great,
After this, issued a no ip route followed by default gateway x.x.x.x and can go out now
