how to remove 4500x vss configuration when stuck in ROMMON
amitpatel0071
I am stuck in ROMMON with the following error. I think the switch was configured for VSS when I erased the configuration it did not remove the VSS configurations and when upgrading the IOS I am now stuck in ROMMON. Anyway out of this?
rommon 18 >reset
Resetting .......
rommon 19 >
 Rommon (G) Signature verification PASSED
 Rommon (P) Signature verification PASSED
 FPGA   (P) Signature verification PASSED
 * Welcome to Rom Monitor for    WS-C4500X-32 System.       *
 * Copyright (c) 2008-2013 by Cisco Systems, Inc.           *
 * All rights reserved.                                     *
 Rom Monitor (P) Version 15.0(1r)SG10
 CPU Rev: 2.2, Board Rev: 9, Board Type: 107
 CPLD Mobat Rev: 2.0x549a.0x59a4
 Chassis: WS-C4500X-32
 MAC Address  : 88-1d-fc-e0-d3-3f
 Ip Address   : Not set.
 Netmask      : Not set.
 Gateway      : Not set.
 TftpServer   : Not set.
 Non-Redundant system or peer not running IOS
 System Uplinks & Linecards have been reset!!
rommon 1 >
Paul Chapman
Level 4
Level 4
Just manually boot the OS.  You should be able to use the "dir" command to find the IOS file on flash.  Once you do that you can use the "boot" command with the IOS path as a parameter.
If you cannot find the IOS file, then you can download it onto a small USB thumb drive (4Gb or less) formatted with FAT32.  You should be able to boot off the thumb drive.
Once you have the OS online, reset the boot variables (boot system flash...) and verify you have the correct config register (0x2101 by default, 0x2102 for VSS).
Good Luck!
PSC
