How to remove ip dhcp relay from a vlan on a NEXUS 7000
rfuentes1111
Hi Team,
We are changing our dhcp address an i need to change my dhcp relay on all my vlan but what is the command to remove the all dhcp relay on the vlan.
This is my vlan
interface vlan10
ip dhcp relay address 192.168.100.42
I need to remove this one but what is the command is no ip dhcp relay address or delete ip dhcp relay.
need some help please thank you.
joebrug
"no ip dhcp relay address 192.168.100.42" should work within each vlan interface needing the change.
So "conf t > int vlan 10 > no ip dhcp relay address 192.168.100.42"
or.. add the new one first, then remove the old one.
Thank you for your help.
