Diagnosing and Troubleshooting ACL's
shankm001
Hi all,
Just wanted some advice on the best way to troubleshoot ACL's on an ASA.
Yesterday while configuring our VPN to AWS, i added a permit ip any any onto the end of an ACL to avoid the implied deny, however it dropped all external (internet access).  From what i know there was a conflict with ACL's somewhere and i would like to find out where.
Is there a way to do this?
Cheers
6 Replies 6
Dennis Mink
If you are running an ASA, use the packet tracer tool in the Cisco ASA, to see, what ACL gets hits for certain interesting traffic.
Please remember to rate useful posts, by clicking on the stars below.
That's awesome, thanks for that!
Now i can see it is being dropped by an ACL, how do i find out which ACL it is?
It passes Phase 1: access list, Phase 2: Route Lookup, Phase 3: UN-NAT, but fails Phase 4: Access-List.
I tried running the packet-tracer command from a different Interfaces IP, for ICMP type 8 code 8.
All results came up allow, however using that interfaces IP as the source, i still do not get a ping response.
However, with hosts within that Interface's range i can get a ping response, also i can ping the ASA's outside interface IP from the other end of the connection, that i am trying to ping (it is an instance in AWS).  The VPN tunnel is up as well.
Out of curiosity, when would you use the crypto map set reverse-route setting?
One of our guys here says to set it so the other internal networks can communicate with the VPN
I havent got it in front of me, but doesnt it tell you exactly why your packet is dropped in phase 4?  can you add a screen shot, so we can have a look at what you are seeing?
Sorry was phase 3
Phase: 3
Type: ACCESS-LIST
Subtype:
Result: DROP
Config:
Implicit Rule
Additional Information:
Forward Flow based lookup yields rule:
in id=0x7fff9f54fd90, priority=500, domain=permit, deny=true
hits=3, user_data=0x6, cs_id=0x0, reverse, flags=0x0, protocol=0
src ip/id=x.x.x.x, mask=255.255.255.255, port=0, tag=0
dst ip/id=0.0.0.0, mask=0.0.0.0, port=0, tag=0, dscp=0x0
input_ifc=outside, output_ifc=any
