How to remove IP from Interface
networker101
Can someone tell me how to remove "IP from the interface"? on a 2950 switch.
interface FastEthernet0/22
no ip address
T
5 Replies 5
N W
Level 3
Level 3
do you want to turn it into a switchport?
Hi Noel,
Yes, all my interfaces are the same - they all the interface number and underneath "no ip address"
To change the IP address, you can either type in new addresses or remove the IP information with the no ip address.
Please rate the helpfull posts.
Naidu.
Sorry, I may have given wrong info.
I want to remove the line where it says "no ip address" on each interface
Sorry for the confusion
If you simply type
Switch(config-if)#switchport
Then you have a switchport.  It runs exacly like a normal switchport whether the 'no ip address' line is there or not.  It's totally cosmetic from that point.  Do you have some sort of compliance check (via CiscoWorks or similar) that searches for this string or something?  Besides that, there is no functionality benefit to removal of this line.
