How to remove or delete port-channel on a Nexus 7000
rfuentes1111
Hi Team,
Can someone help I need to remove or delete a Port-channel on a Nexus 7000 and create a new one how can i accomplish this fi you can help thank you.
Reza Sharifi
Try this command:
example:
no interface port-channel 20
Than create a new one by simply adding the physical interfaces to it
example:
inter e1/1
channel-group 30 mode active
this is if you want to run LACP.
after this, issue "no sh" under interface po30.
Reza Sharifi
Try this command:
example:
example:
inter e1/1
I will try that thank you for your help.
