how to reset a BGP ipv6 BGP peer under a vrf address family?
Yonglu Jian
Dear All,
I am doing some test with IPv4 & IPV6 BGP peering under a vrf address family. If I want to soft reset a IPv4 peer I have to do the following:
clear ip bgp x.x.x.x vrf abc soft
But I can't find the command to soft reset the IPv6 bgp peers. I tried the following commands and they didn't work.
router#clear bgp vrf abc vpnv6 unicast 2400:1::1 soft in
% Topology not found
br01.syd02#clear bgp ipv6 unicast 2400:1::1 soft
% BGP: Unknown neighbor - "2400:1::1"
Can someone assist? Much apprecaite it!
Dennis
Yonglu Jian
found it:
it should be:
clear bgp vrf abc ipv6 unicast 2400:1::1 soft
took me a while to find it. The commands do not have consistency at all. For example, the show commands are:
show bgp vpnv6 unicast vrf abc neighbor 2400:1::1
It use the keyword "vpnv6" in the "show" command and "ipv6" in the "clear" command. Also the support documents are not very helpful in this case.
