HOW TO RESOLVE SNMP TO BIG ERRORS?
jose-rangel1
378759 SNMP packets input
0 Bad SNMP version errors
1525 Unknown community name
0 Illegal operation for community name supplied
0 Encoding errors
986776 Number of requested variables
0 Number of altered variables
18081 Get-request PDUs
29470 Get-next PDUs
0 Set-request PDUs
0 Input queue packet drops (Maximum queue size 1000)
377234 SNMP packets output
86 Too big errors (Maximum packet size 1500)
0 No such name errors
0 Bad values errors
0 General errors
377234 Response PDUs
0 Trap PDUs
SNMP global trap: enabled
SNMP agent enabled
SNMP logging: disabled
My switch doesn't connect to my auvik collector.
Giuseppe Larosa
Hello @jose-rangel1 ,
you have only 86 too big errors but you have also:
so check if the SNMP community settings are correct on the auvik collector because the other error is simply a rare event compared to total number of input SNMP packets that is :
Too Big simply means the received packet was bigger then IP MTU on receiving interface.
A wrong SNMP community does not get answered
Edit:
actually the 86 too big are in the output section of the show command so they refer to outbound tx packets not to received packets
RX packets - TX packets = 378759 - 377234 = 1525  = unknown Community counter
Hope to help
Giuseppe
