16amp or 32amp power breaker required
sgooding
Hi Cleaver Cisco People ,
For the asr-9910 is a 16amp or a 32amp breaker required .
Same question for the ASR-9906 & 9904 .
UK based
2 Accepted Solutions
Mark Elsen
  - Overall power consumption will depend on what modules are being used on the devices too ;
    start with : https://cpc.cloudapps.cisco.com/cpc/launch.jsp
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Reza Sharifi
6 Replies 6
Mark Elsen
 M.
       Beauty and terror
      Just keep going
       No feeling is final
Thank you for your reply , I have not seen the build spec yet . I have a project soon to rack these devices and survey power availability but that’s hard to do when I have not been given the info on power modules that have been installed so unsure if I should be looking for 16 Or 32a outlets , . Don’t even know what power cables are required , if they are c15,c19,c21 ends that connect into the modules . Thanks for the power table link I’m sure it will help .
Reza Sharifi
https://www.cisco.com/c/en/us/td/docs/iosxr/asr9000/hardware-install/overview-reference/b-asr9k-overview-reference-guide/b-asr9k-hardware-installation-guide_chapter_011.html
Have a look at Table 3.
Source AC service requirement
20 A North America;
16 A international;
13 A United Kingdom
Thank you for that. Was thinking it would possibly creep up to needing a 32a socket depending on the cards the device was specked with.
You should not need 32a. According to the document, for the UK, 13 a.m. per circuit should do it.
Thank you
