How to restrict Bandwidth based on routing destination
jpflory01
I have a visitor VLAN that needs to be bandwidth constrained when leaving the local LAN, but not bandwidth constrained when switching vlans on the local LAN.
MY topography is as follows:
10.x.0.0/16= (Local Lan)   =====> 192.168.x.0/24 (Transport WAN)  ==========> Internet
Catalyst 4503/7LE (local LAN) -------->ASA5512X --------------------------------------------->ISR-4321.
Packets that stay on the Local Lan, get switched at the Catalyst 4503 level.
Packets destined for the internet go from Left to right across the topology.
I just started reading the QOS document for the 4500 series*, and it states that QOS values are marked and then routing is applied. So, I am thinking this is not going to work.What other mechanisms exist that would help accomplish this?
* = http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/12-2/3-1-1SG/configuration/guide/config/qos.html#wp1462826
Thanks for your comments and knowledge
Zach S
I think you might be able to accomplish it with the following.
Define an extended ACL that would match the source destination to the destination you want to limit. Then define a route map, and match it to that ACL, then set a QoS group for the matches. Then set a class-map matching the same QoS group and a policy map to that group that limits bandwidth. Finally apply the route map and service policy to the interfaces that you want the limitations on:
ip access-list extended LIMIT
   10 permit ip any 192.168.1.1 0.0.0.0
route-map LIMIT
   match ip address LIMIT
   set ip qos-group 1
class-map match-all LIMIT
    match qos-group 1
policy-map LIMIT
   class LIMIT
   bandwidth percent 10
int s0/0
   ip policy route-map LIMIT
   service-policy {output | input} LIMIT
Zach S
route-map LIMIT
   set ip qos-group 1
    match qos-group 1
policy-map LIMIT
   class LIMIT
int s0/0
Zach,
Thanks for your reply, I followed the instructions and researched some of the commands, and wrote them into the Router closest to the PE. I am still working on configuration , since I can't ping through the router, but I wanted to give you the credit for answering the original question.
This discussion has been reposted from Additional Communities to the LAN, Switching and Routing community.
