how to see if traffic is using priority queue
carl_townshend
Hi all
on my switches, 2960's, how can i check that traffic is going to the correct queue, ie my voice goes to the priority queue
cheers
Carl
Shashank Singh
Hi Carl,
There is no direct command that shows the packets going in the priority queue. However we can get a picture by the following outputs:
switch# sh mls qos int gi x/y statistics
Find out the marking of the traffic supposed to go to priority queue and check if the corresponding counters are incrementing for " dscp: outgoing"
Once you find the counters incrementing, check which queue is the corresponding dscp mapped to:
switch#sh mls qos maps dscp-output-q
  Dscp-outputq-threshold map:
     d1 :d2    0     1     2     3     4     5     6     7     8     9
      0 :    02-01 02-01 02-01 02-01 02-01 02-01 02-01 02-01 02-01 02-01
      1 :    02-01 02-01 02-01 02-01 02-01 02-01 03-01 03-01 03-01 03-01
      2 :    03-01 03-01 03-01 03-01 03-01 03-01 03-01 03-01 03-01 03-01
      3 :    03-01 03-01 04-01 04-01 04-01 04-01 04-01 04-01 04-01 04-01
      4 :    01-01 01-01 01-01 01-01 01-01 01-01 01-01 01-01 04-01 04-01
      5 :    04-01 04-01 04-01 04-01 04-01 04-01 04-01 04-01 04-01 04-01
      6 :    04-01 04-01 04-01 04-01
For eg, if you have voice traffic which is supposed to go to priority queue, make sure counters for 'dscp: outgoing' are incrementing against 46.(first command). Next check the map, and ensure that dscp 46 is mapped to queue 1 (priority queue on 2960).
Hope this helps,
Shashank
Please rate if you found the content useful
