How to set login username and password for telnet and ssh?
vinothlb1
7 Replies 7
platinum_jem
aaa new-model
aaa authentication login default local enable
username user1 password mypassword
#### Below is the enable password ###
enable password mypassword
The above command will set user logins for both telnet and SSH.
Hope this helps.
without enabling
aaa new-model
how to set username and password for telnet and ssh
username jdoe privilege 15 password cisco
line vty 0 4
login local
hi there
what is the, enable bit for at the end of the following command ?
cheers
Means that you can use the enable password to login if for some reason there is no UN or PW configured.
Thanks for your help.
Hello
The below should provide you with local privilege level 15 access for line interfaces
conf t
username AdmiN privilege 15 secret xxxxx
aaa new-model
aaa authentication login default local-case
aaa authorization exec default local if-authenticated
aaa authorization console
Lastly telnet /ssh will be enabled by default on all vty lines but this can be restricted ingress/egress if you wish to.
Kind Regards
Paul
