How to set port speed on 2960 automatically (SNMP or smth else)?
ivanb21vania
Can you please help me with subject?
I tried to do it using SNMP, but it failed...
I can set port UP or DOWN using a script (just set SNMP OID values), but I need to set a port speed (10/100/1000).
Surely I know how to set port speed using tty )
Thank you in advance!
Ivan.
Ganesh Hariharan
Ivan.
Ivan,
With SNMP try MAU-MIB.
Here is an example.
mnie@nms-server2[118]:/home/mnie{17:25:35}% snmpwalk -c public 172.21.50.250
ifMauDefaultType.5.1
MAU-MIB::ifMauDefaultType.5.1 = OID: SNMPv2-SMI::zeroDotZero
Now set it to dot3MauType100BaseTXHD
mnie@nms-server2[120]:/home/mnie{17:27:14}% snmpset -c private 172.21.50.250
ifMauDefaultType.5.1 o
MAU-MIB::ifMauDefaultType.5.1 = OID: MAU-MIB::dot3MauType100BaseTXHD
mnie@nms-server2[121]:/home/mnie{17:27:32}% snmpwalk -c private 172.21.50.250
It also works with the object id. Make sure you put the dot at front.
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
