How to setup connection on 2650 router with cable modem
mahesh18
Level 6
Level 6
I have cisco 2650 router and i want this to connect to Cable modem --ISP.
i need to know what config commands i should config on router.
My router has 2 lan fastethernet interfaces.I will go to cable modem.
Other to my home pc.
Many thanks
Mahesh
Ganesh Hariharan
Check out the below link hope this helps out your query !!
http://www.cisco.com/en/US/docs/ios/cable/command/reference/cbl_01_a_to_cable-modem.html
Ganesh.H
