How to setup NVI?
techfactor13
Was wondering if someone could look at my current config and help me enable and setup NVI on a cisco 1941 router.
i think it would fix my issue but i'm unclear on how to implement it to test.
i would like to be able to access an internal server from an outside address.
i appreciate any help, thanks
cadet alain
replace ip nat inside and ip nat outside on interfaces by:
ip nat enable
no ip redirect
Then replace your NAT inside statements by deleting the inside keyword and it should work.
Regards.
Alain
thanks, any chance you could look at my config and give some pointers on NAT statements?
you can post  your config indeed.
Regards.
Alain
k, thanks again for your help
here it is,
version 15.1
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service sequence-numbers
boot-start-marker
boot-end-marker
aaa new-model
service-module wlan-ap 0 bootimage autonomous
no ipv6 cef
no ip source-route
ip cef
no ip bootp server
ip domain name company.com
ip name-server 111.111.111.222
ip name-server 10.10.20.2
redundancy
interface Embedded-Service-Engine0/0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
shutdown
interface GigabitEthernet0/0
description $ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$$ES_LAN$$FW_INSIDE$$ETH-LAN$
ip address 10.10.20.1 255.255.255.0
ip helper-address 10.10.20.2
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
ip virtual-reassembly in
duplex auto
speed auto
no mop enabled
interface wlan-ap0
description Service module interface to manage the embedded AP
ip unnumbered GigabitEthernet0/0
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
arp timeout 0
no mop enabled
no mop sysid
interface GigabitEthernet0/1
description $ES_WAN$$FW_OUTSIDE$$ETH-WAN$
ip address 111.111.111.111 255.255.255.248
no ip redirects
no ip unreachables
no ip proxy-arp
ip nbar protocol-discovery
ip flow ingress
ip flow egress
ip nat outside
duplex auto
speed auto
no mop enabled
crypto map SDM_CMAP_1
interface Wlan-GigabitEthernet0/0
description Internal switch interface connecting to the embedded AP
no ip address
interface Vlan1
ip address 10.10.21.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip flow-export destination 10.10.20.32 2055
ip nat inside source static tcp 10.10.20.7 25 interface GigabitEthernet0/1 25
ip nat inside source static tcp 10.10.20.7 443 interface GigabitEthernet0/1 443
ip nat inside source static tcp 10.10.20.7 3101 interface GigabitEthernet0/1 3101
ip nat inside source static tcp 10.10.20.7 53 interface GigabitEthernet0/1 53
ip nat inside source static udp 10.10.20.2 123 interface GigabitEthernet0/1 123
ip nat inside source static tcp 10.10.20.7 80 interface GigabitEthernet0/1 80
ip nat inside source route-map SDM_RMAP_1 interface GigabitEthernet0/1 overload
ip nat inside source static tcp 10.10.20.5 80 111.111.111.112 80 extendable
ip nat inside source static tcp 10.10.20.5 443 111.111.111.112 443 extendable
ip route 0.0.0.0 0.0.0.0 111.111.111.110 254
logging trap debugging
access-list 1 remark INSIDE_IF=GigabitEthernet0/0
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 10.10.20.0 0.0.0.255
access-list 1 permit 10.10.21.0 0.0.0.255
access-list 1 permit 192.168.10.0 0.0.0.255
access-list 1 permit 192.168.20.0 0.0.0.255
access-list 100 remark CCP_ACL Category=4
access-list 100 remark IPSec Rule
access-list 100 permit ip 111.111.111.109 0.0.0.7 192.168.10.0 0.0.0.255
access-list 101 remark CCP_ACL Category=2
access-list 101 permit tcp 10.10.20.0 0.0.0.255 eq 443 host 000.000.000.000 eq 443
access-list 103 remark CCP_ACL Category=2
access-list 103 remark IPSec Rule
access-list 103 deny   ip 10.10.20.0 0.0.0.255 192.168.10.0 0.0.0.255
access-list 103 permit ip 10.10.21.0 0.0.0.255 any
access-list 103 remark P-Internal
access-list 103 permit ip 10.10.20.0 0.0.0.255 any
access-list 103 permit ip 192.168.10.0 0.0.0.255 any
access-list 103 permit ip 192.168.20.0 0.0.0.255 any
access-list 104 remark CCP_ACL Category=4
access-list 104 remark IPSec Rule
access-list 104 permit ip 10.10.20.0 0.0.0.255 192.168.10.0 0.0.0.255
access-list 106 remark CCP_ACL Category=4
access-list 106 remark IPSec Rule
access-list 106 permit ip 10.10.20.0 0.0.0.255 192.168.10.0 0.0.0.255
access-list 107 remark CCP_ACL Category=4
access-list 107 remark IPSec Rule
access-list 107 permit ip 10.10.20.0 0.0.0.255 192.168.10.0 0.0.0.255
access-list 108 remark CCP_ACL Category=4
access-list 108 remark IPSec Rule
access-list 108 permit ip 10.10.20.0 0.0.0.255 192.168.10.0 0.0.0.255
access-list 115 remark 443
access-list 115 remark CCP_ACL Category=16
access-list 115 permit tcp any eq 443 any eq 443
no cdp run
route-map SDM_RMAP_1 permit 1
match ip address 103
control-plane
end
