how to tell what ip address bgp neighbor is using for peering
spencerlin1991
hello all,
how to tell what ip address bgp neighbor is using for peering? is there such command to check for this?
thanks
You can use:
show ip bgp summary
show ip bgp neighbor
show ip bgp; will show you the local router-id.
Hope it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
thank you for the reply.
i mean without getting into remote router, how do i know what IP address "neighbor x.x.x.x" remote router is using for BGP peering session?
Unfortunately there is no such command directly but it can be found through show ip bgp neighbor, you could execute a debug or use wireshark. Other way is to see the neighbor IP and see the matching with the local networks like point to point networks or if you are using loopbacks you can see the associated local IP displayed on the command: neighbor x.x.x.x update-source <interface>
Hello
Along with the otherssuggestions
Bgp  will peer on the address specifed in the BGP routing stanza so you can take it from there or use pipeon the sh ip bgp neighbors commnad
sh ip bgp neighbors | in Local|Foreign
res
Paul
res
Paul
Kind Regards
Paul
