How to telnet Router using Loopback address
mahesh18
Level 6
Level 6
On my router and switches  i assigned IP address to loopback interfaces.
I do no have any tacacs server is there any way i can access the router using loopback IP address?
MAhesh
    It's an IP address on the device(in your case).  You need to reach that IP address(via routing protocol or static route etc). All configuration on vty lines are the same.
F.e
interface loopback 99
description  Management IP
ip add 99.99.99.99 255.255.255.255
HTH,
Toshi
     As long as you can reach loopback's ip address you will still access the router via that IP address. Tacacs is a part of AAA components.  You can use local user/line to authenticate users as well. No need to use tacacs till you want to.
HTH,
Toshi
Hi Toshi,
Right now i am able to telnet router -- by IP address assigned to Fast interface.
I have also set up user name and pw.
but i was wondering  if i can telnet the router using loopback IP ?
For normal telnet we do line vty 0 15
and config the telnet
But for Loobback  interface i do not  know how cani config it?
F.e
HTH,
Toshi
Hi Toshi,
I understand your reply.
Thanks for help again
regards
mahesh
