How to trace console connection from switch back to terminal server?????
adeelmir mir
Hello Folks,
I am wondering is there any way that you could trace console connection back to switch and could figure out what port is in use on terminal serer for that specific console connection , for example
SwitchA# console is connected to    port 0/1/8 on terminal server ,
is there any command that by logging on SwitchA# we could tell which port on terminal server is being mapped?
Hello
On the terminal server you could
show lines
res
Paul
Kind Regards
Paul
You are right Paul , yes it can be done on TS but i am wondering is it possible to do it on the switch/router connected to terminal server..
