How to upgrade C3550-24-EMI
arifdatau
I need your help in the process of upgrading IOS image in this particular switch to c3550-ipservicesk9-mz.122-44.SE6.bin. Thank you for your help.
SW1#sh version
IOS (tm) C3550 Software (C3550-I5Q3L2-M), Version 12.1(11)EA1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Wed 28-Aug-02 10:03 by antonino
Image text-base: 0x00003000, data-base: 0x0071D658
ROM: Bootstrap program is C3550 boot loader
ALS1 uptime is 1 day, 14 hours, 0 minutes
System image file is "flash:c3550-i5q3l2-mz.121-11.EA1/c3550-i5q3l2-mz.121-11.EA1.bin"
cisco WS-C3550-24 (PowerPC) processor (revision G0) with 65526K/8192K bytes of memory.
Processor board ID CHK0641V18Z
Last reset from warm-reset
Bridging software.
Running Layer2/3 Switching Image
Ethernet-controller 1 has 12 Fast Ethernet/IEEE 802.3 interfaces
Ethernet-controller 2 has 12 Fast Ethernet/IEEE 802.3 interfaces
Ethernet-controller 3 has 1 Gigabit Ethernet/IEEE 802.3 interface
Ethernet-controller 4 has 1 Gigabit Ethernet/IEEE 802.3 interface
24 FastEthernet/IEEE 802.3 interface(s)
2 Gigabit Ethernet/IEEE 802.3 interface(s)
The password-recovery mechanism is enabled.
384K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:0B:46:3A:4C:00
Motherboard assembly number: 73-5700-09
Power supply part number: 34-0966-02
Motherboard serial number: CAT063904BM
Power supply serial number: DCA063810V1
Model revision number: G0
Motherboard revision number: A0
Model number: WS-C3550-24-EMI
System serial number: CHK0641V18Z
Configuration register is 0x10F
Leo Laohoo
You can upgrade to 12.2 version IOS as long as you have a valid Cisco Service Contract.
Go here to find the IOS.
Leo Laohoo
Leo Laohoo
Thanks for the ratings and quick feedbacks.
Download the "TAR" file and use the proceedure below:
Step-by-Step Procedure for the 3550 with Use of the CMS Image (.tar File)
You are very welcome!
I had bad experiences in the passed when upgraded image that located on top of that image dir before. That is why I need to make sure I run the proper step. Let me go through with the link you gave me and I hope you mind I'am asking if I might stumble into some problem.
No, we don't mind if you ask more question.
Before I forget ... Before pushing the IOS to the switch, make sure you check (and compare) the hash to ensure the IOS file you downloaded is either complete and/or not corrupted.
