how to use ACL to control VLAN traffic ?
dannan lin
hi:
i have a question here.
how do i use ACl to limit access between different vlans.
from above  picture, there are two vlans - vlan 10 and vlan 20, both are connected to a router via a switch.  their addresses are assigned by dhcp.
so far vlan 10 and vlan 20 can ping each other.
1. what if i do not want pc from vlan 10 to access pc from vlan 20
2. while vlan 20 can access vlan 10
3. and remain dhcp function.
assuming pc1 from vlan 10 is 1.1.1.1
and pc2 from vlan 20 is 2.2.2.2
please help.
thanks in advance
johnlloyd_13
Level 9
Level 9
hi dannan,
Router#sh ip int bri
Interface              IP-Address      OK? Method Status                Protocol
FastEthernet0/0        unassigned      YES unset  up                    up
FastEthernet0/0.10     1.1.1.254       YES manual up                    up
FastEthernet0/0.20     2.2.2.254       YES manual up                    up
FastEthernet0/1        unassigned      YES unset  administratively down down
Vlan1                  unassigned      YES unset  administratively down down
Router(config)#access-list 1 deny 1.1.1.0 0.0.0.255
Router(config)#access-list 1 permit any
Router(config)#int f0/0.10
Router(config-subif)#ip access-group 1 out
thanks, it worked .
i know what you did is to limit any outgoing traffic .
but i want to know why i can't use
Router(config)#access-list 1 deny 2.2.2.0 0.0.0.255
Router(config-subif)#ip access-group 1 in
if i want to block incoming traffic from 2.2.2.254
thanks
