How to use C9400-SUP-UPG-LIC
chenpan1127
I have a question,  How to activate C9400-SUP-UPG-LIC=   LIC?
pieterh
do not see this SKU mentioned anywhere in the 9400 ordering guide ?
Cisco Catalyst 9400 Series Switches Ordering Guide - Cisco
but:
High Availability Configuration Guide, Cisco IOS XE Fuji 16.9.x (Catalyst 9400 Switches) - Configuring Cisco StackWise Virtual [Support] - Cisco
  • Cisco StackWise Virtual is supported on Cisco Catalyst 9400 Series Supervisor 1 Module (C9400-SUP-1) and Cisco Catalyst 9400 Series Supervisor 1XL Module (C9400-SUP-1XL). The feature requires a special, additional, C9400-SUP-UPG-LIC= license with Cisco Catalyst 9400 Series Supervisor 1 Module (C9400-SUP-1).
maybe it was pre-installed on the SUP and no action is needed?
-> try the command show license summary
Reza Sharifi
Have a look at table-11 in this link for the type of license packages you can install on the 9400. If you want to know what license you currently have, try "sh license right-to-use" or "sh ver"
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-9400-series-switches/nb-06-cat9400-ser-sup-eng-data-sheet-cte-en.html
