how to use sniffer on Packet tracer
Salim.H.H
Good Afternoon everyone,
I have assignment that i need to create full "Network", using all device like switch, hub, server ..etc.
The problem that i force that i need to use "Sniffer" its first time to me using that device.
I need help how can i configure or connect the Sniffer with my network, Because i search on internet i don't find anythings about configure or connect sniffer on packet tracer.
Please help me to solve and finish my assignment.
Regards;
Salim
Mark Malone
connect the laptop to the switch , run wireshark on the laptop and select the local GB adapter in the settings on main screen that's connected to the switch and press start and it will start capturing traffic , stop to stop it , this guide below shows a quick use of it
https://www.howtogeek.com/104278/how-to-use-wireshark-to-capture-filter-and-inspect-packets/
changtim
luis_cordova
Hello
Connect the sniffer to the switch.
On the switch, enter these commands so that the packets are duplicated and forwarded to the sniffer:
S(config)#monitor session 1 source interface f0/x <--if you want to sniff packets from only one interface
or
S(config)#monitor session 1 source vlan <n°> <--if you want to sniff packets from an entire vlan
S(config)#monitor session 1 destination interface f0/x <--interface where the sniffer is connected
