How to verify which interface of an etherchannel a particular flow will use on a 3850 switch
CHRISTINE BERNS
Is there a command similar to "test etherchannel load-balance int port-channel #  ip 1.1.1.1 2.2.2.2"  (available on the 3750 switches)  for 3850 switches.   I cannot find a way to test which interface of a port channel a particular flow will use.
naseromer
did you try this command
show etherchannel  (number) port-channel
Yes, but "show etherchannel # port-channel" does not allow you to specify a particular source and destination IP to determine which one of the individual interfaces of the port channel the traffic from the specified source IP to the specified destination IP will use.
