How to view VTP password after configured?
jaiwaei36
Hi, does anyone know how to view VTP password after configured for Catalyst 9K series? The password can be seen via the output of "show vtp status or show vtp password".
5 Replies 5
Martin L
Yes, you should see it with show vtp password command
Regards, ML
**Please Rate All Helpful Responses **
Mark Elsen
               - Isn't the question contradictory ?
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
M02@rt37
Helo @jaiwaei36
You can use the "shw vtp password" command in privileged mode to view the password in cleartext if you're using VTPv1 or VTPv2. However, with VTPv3, the password is encrypted and can't be seen in cleartext.
Regardless of the version, you can always change the VTP password through global configuration.
Best regards
Blue_Bird
Hello jaiwaei36,
Check the vtp version running on the switch using  show vtp status,  if the switch is running with vtp version 1  or 2 shows the password in clear text with show vtp password command. However, switch is configured with vtp version 3, when you give show vtp password, it doesn't show the password, insted it show's the message VTP Password is configured.
Best regards
******* If This Helps, Please Rate *******
Hi Gopi,
Although is version 1, the vtp password still not showing as clear text. Kindly refer below is the result from the switch:
TLC-A02SW-A02#show vptp status
VTP Version capable : 1 to 3
VTP version running : 1
VTP Domain Name : TLC-BlkA
VTP Pruning Mode : Enabled (Operationally Enabled)
VTP Traps Generation : Enabled
Device ID : 2416.9d14.7c80
Configuration last modified by 10.99.4.37 at 9-3-24 14:14:48
Feature VLAN:
VTP Operating Mode : Client
Maximum VLANs supported locally : 1005
Number of existing VLANs : 48
Configuration Revision : 105
MD5 digest : 0x53 0x9F 0xD6 0xA5 0xCF 0x8B 0x48 0xED
0x82 0x18 0xBE 0xAA 0x4E 0x9A 0x38 0x3C
TLC-A02SW-A02#
TLC-A02SW-A02#
TLC-A02SW-A02#show vtp password
TLC-A02SW-A02#
