how we can tell if 2 IPs ar ein same or different broadcast doamins
mahesh18
Level 6
Level 6
I have these two IPs
IP 1---192.168.1.1/24
IP 2-----192.168.2.1 /24
Many thanks
mahesh
With all the emphasis on broadcast domains and L2, but since the original question referenced IP subnets, I did want to mention broadcasts themselves are not limited to just L2. For instance, IP can "route" an IP (directed) broadcast to a subnet.
Giuseppe Larosa
Hello Mahesh,
the /24 notation means that the subnet mask is formed by 24 ones followed by 32-24 = 8 zeros
192.168.1.1 255.255.255.0
net part : 192.168.1.0 host part 1
the same for 192.168.2.1/24
192.168.2.1 255.255.255.0
net part : 192.168.2.0 host part 1
net 192.168.1.0 <> net 192.168.2.0
the two ip addresses are in different subnets
a broadcast domain is a layer 2 concept: it is the set of switch ports that receive the same broadcast frame.
the two hosts need a router device cannot talk directly
Hope to help
Giuseppe
Joseph W. Doherty
You can't, unless you now whether the two subnets are virtually or physically separated, and if conneced within a routed environment, how broadcasts are forwarded, or not.
Normally, one would expect two separate subnets would not be within the same broadcast domain, but they can be.
Mahesh
I like parts of both responses. I especially like the point that Guiseppe makes that a broadcast domain is a layer 2 concept. And related to that is the point from Joseph that "You can't, unless you now whether the two subnets are virtually or physically separated". To expand on this point a bit: broadcast domains are layer 2 concepts while IP addresses and subnets are layer 3 concepts. You can not look at layer 3 IP addresses and subnets and know for sure what the layer 2 reality is.
As they both sort of say, we make assumptions about relationships between layer 2 and layer 3. One of our assumptions is that a subnet should be its own broadcast domain and when there are 2 separate IP networks there should be 2 separate broadcast domains. But it is quite possible to have a single broadcast domain (perhaps a single VLAN) and to put 2 separate IP networks into it.
It is also true that if you break some assumptions (like the assumption that a subnet should be its own broadcast domain) other assumptions about how things should work (like devices in separate subnets must have a router to communicate) may no longer be true.
Rick
Rick
