HSRP active without priority en preempt
blacktrack
Community Member
I have 2 router R1 and R2 with ip address 10.10.10.1 and 10.10.10.2. 10.10.10.3 is the stanby address. both have default 100 priority.
I would like to know if i can make R1 active without changing the priority and without using preempt command ?
A friend told me there is maybe a way using mac address ...
Do you think it's possible ?
cadet alain
The only way to do this is to change  R1 ip address because when priority is equal then ip address is tie-breaker.
Regards.
Alain.
When i changed R1 ip address with 10.10.10.4 and shuting down the interface R1 still stay in standby !
yes because preempt not configured.
take off hsrp and reenable and it should work.
Regards.
alain.
