hsrp active
aslam mohammad
hi,
hsrp routers both are active active state.what is the reason how to troubleshoot and what are things need to check.
Reza Sharifi
They are both active maybe because they can't see each other.  So, check connectivity between the 2 routers.  How are they connected? Are you using a switch or directly connected?
Can you ping each device?
