HSRP and WCCP
mlitka
Level 2
Level 2
We are looking at a WAFS solution which would use WCCP to push CIFS traffic to a out of line box.
What are the implications of using WCCP on an HSRP pair? What happens when the pair changes states? Will WCCP get confused? Is it session based? Will the client need to restart their session with the content provider that WCCP is pushing to?
wong34539
Level 6
Level 6
Cisco Hot Standby Router Protocol (HSRP) to create redundant fail-safe routing topologies. Whereas WCCP allows the interaction with a web cache for the purpose of redirecting content requests to a cache and performing basic load balancing across multiple caches-requires EMI.
