HSRP - Both Active in slave groups
pietrodiblasi
Hi all,
I work at an ISP and I want to implement HSRP to give some protection to my clients.
All clients are connected to 2 routers(RT02 and RT03) over a single interface on each router. Clients are separated by subinterface.
To minimize any effect in the router processor due to the quantity of vlans in use, i was testing HSRP with command "standby follow".
I've choosed a vlan of control to exchange messages of HSRP protocol and set the others vlans to follow this master vlan.
The HSRP works fine but when i do a shut on the master vlan that is in the active router, the state of all slave vlan doesn't change.
Output bellow:
Before shut
RT02RT03
TenGigabitEthernet3/2.2706 - Group 2706 (version 2)
  State is Standby
    22 state changes, last state change 01:48:30
  Virtual IP address is 186.219.34.97
  Active virtual MAC address is 0000.0c9f.fa92
    Local virtual MAC address is 0000.0c9f.fa92 (v2 default)
  Hello time 3 sec, hold time 10 sec
    Next hello sent in 2.400 secs
  Authentication text, string "2706"
  Preemption enabled
  Active router is 186.219.34.99, priority 160 (expires in 9.552 sec)
    MAC address is ccef.48d0.3c00
  Standby router is local
  Priority 150 (configured 150)
  Group name is "HSRP_MASTER" (cfgd)
  Followed by groups:
    Te3/2.2703 Grp 2703 Standby 186.219.20.25 0000.0c9f.fa8f refresh 10 secs
    Te3/2.2704 Grp 2704 Standby 186.219.32.97 0000.0c9f.fa90 refresh 10 secs
TenGigabitEthernet2/1.2706 - Group 2706 (version 2)
  State is Active
    26 state changes, last state change 01:49:02
    Next hello sent in 2.464 secs
  Preemption enabled
  Active router is local
  Standby router is 186.219.34.98, priority 150 (expires in 8.576 sec)
  Priority 160 (configured 160)
  Followed by groups:
    Te2/1.2703 Grp 2703 Active 186.219.20.25 0000.0c9f.fa8f refresh 10 secs (expires in 7.200 sec)
    Te2/1.2704 Grp 2704 Active 186.219.32.97 0000.0c9f.fa90 refresh 10 secs (expires in 8.240 sec)
After shut:
RT02RT03
  State is Active
    23 state changes, last state change 00:00:11
    Next hello sent in 1.392 secs
  Preemption enabled
  Standby router is unknown
  Followed by groups:
    Te3/2.2703 Grp 2703 Active 186.219.20.25 0000.0c9f.fa8f refresh 10 secs
(expires in 6.528 sec)
    Te3/2.2704 Grp 2704 Active 186.219.32.97 0000.0c9f.fa90 refresh 10 secs
(expires in 7.968 sec)
  State is Init (interface down)
    27 state changes, last state change 00:00:06
  Active virtual MAC address is unknown
  Preemption enabled
  Active router is unknown
Followed by groups:
    Te2/1.2703 Grp 2703 Active - master disabled
    Te2/1.2704 Grp 2704 Active - master disabled
This condition is normal? This means that all slave group are in standby state on RT03?
I mean, is the HSRP working properly?
A mensagem foi editada por: Pietro Di Blasi Config attached
Rick Morris
Level 6
Level 6
Can you post the HSRP config for both routers?
Documents attached!
Sorry, it is a .zip file and I cannot open them on my workstation for security purposes, mainly because it cannot inspect the zip file without unpackaging it.  Are you able to just cut and paste the hsrp config specifics?
Sorry...
RT03
interface TenGigabitEthernet2/1.2703
description Teste HSRP
bandwidth 1000
encapsulation dot1Q 2703
ip address 186.219.32.115 255.255.255.248 secondary
ip address 186.219.20.27 255.255.255.248
no ip redirects
no ip unreachables
no ip proxy-arp
standby version 2
standby 2703 ip 186.219.20.25
standby 2703 ip 186.219.32.113 secondary
standby 2703 authentication 2703
standby 2703 follow HSRP_MASTER
service-policy input 1M
service-policy output 1M
interface TenGigabitEthernet2/1.2704
bandwidth 1000
encapsulation dot1Q 2704
ip address 186.219.32.99 255.255.255.248
no ip redirects
no ip unreachables
no ip proxy-arp
standby version 2
standby 2704 ip 186.219.32.97
standby 2704 authentication text 2704
standby 2704 follow HSRP_MASTER
service-policy input 1Mb
service-policy output 1Mb
interface TenGigabitEthernet2/1.2706
bandwidth 1000
encapsulation dot1Q 2706
ip address 186.219.34.99 255.255.255.248
no ip redirects
no ip unreachables
no ip proxy-arp
standby version 2
standby 2706 ip 186.219.34.97
standby 2706 authentication text 2706
standby 2706 priority 100
standby 2706 preempt
standby delay minimum 30 reload 60
standby 2706 name HSRP_MASTER
RT02
interface TenGigabitEthernet3/2.2703
bandwidth 1000
ip address 186.219.32.114 255.255.255.248 secondary
ip address 186.219.20.26 255.255.255.248
no ip redirects
no ip unreachables
no ip proxy-arp
standby version 2
interface TenGigabitEthernet3/2.2704
bandwidth 1000
ip address 186.219.32.98 255.255.255.248
no ip redirects
no ip unreachables
no ip proxy-arp
standby version 2
interface TenGigabitEthernet3/2.2706
bandwidth 1000
ip address 186.219.34.98 255.255.255.248
no ip redirects
no ip unreachables
no ip proxy-arp
standby version 2
standby 2706 priority 150
