HSRP issue on Nexus 7018
c.tabassum
we are current running 5.1(3) NX-OS
The senario is as follows
Both servers are connected to SW1
Box1 = 10.10.20.20 VLAN 20
Box2 = 10.10.40.20 VLAN 40
SW1= 10.10.20.3 HSRP Active GW 10.10.20.1
SW2= 10.10.20.2 HSRP Standby GW 10.10.20.1
SW1= 10.10.40.3 HSRP Active GW 10.10.40.1
SW2= 10.10.40.2 HSRP Standby GW 10.10.40.1
From Box1(10.10.20.20) trying to traceroute Box2 (10.10.40.20); the tracroute is showing the next-hope as 10.10.20.3 (SW1 IP as HSRP Active)
But
From Box2(10.10.40.20) trying to traceroute Box1 (10.10.20.20); the tracroute is showing the next-hope as 10.10.40.2 (SW2 IP as HSRP Standby)
Why the communication between Box2 to Box1 is using the HSRP standby IP of SW2 to reach its destination?
5 Replies 5
Reza Sharifi
What is the output of "sh hsrp brief" from both switches?
The HSRP is showing the correct Active and Standby IP as follows
Active                        Standby
10.10.20.3                10.10.20.2
10.10.40.3                10.10.40.2
And this happening for only one VLAN 40, don't know why?
You may want to clear the ARP table for vlan 40 and test again.
Did that as well but no change?
zeuscyril
Level 4
Level 4
hi,
can you send hsrp config for both vlans and the status output also
