hsrp - issue
dave dave
hi! recently i setup a 3560 L3 sw with hsrp wiht the following configs. Currently i only have 1x 3560 L3 switch, but aonther unit will only be in at later stage. I noticed that with this standalone 3560 switch, the vlan interface protocol   is always down. It will only be up if i configure the switch port with that particular vlan and with a host connected to that port. when no host is connected to it, vlan interface protocol will always be down. Even if the host is connected to that vlan, it will take a few minutes before it's up again. Has anyone encounter this before? My understand is that even if with one switch running the vlan interfaces shd always be up. Any idea? Thanks.
interface Vlan18
description VLAN 18 Mgt
ip address 10.18.8.2 255.255.255.0
standby 1 ip 10.18.8.1
standby 1 priority 120
standby 1 preempt
interface Vlan19
description VLAN 19 Svr
ip address 10.18.9.2 255.255.255.0
standby 1 ip 10.18.9.1
standby 1 preempt
interface Vlan20
description VLAN 20 client
ip address 10.18.10.2 255.255.255.0
standby 1 ip 10.18.10.1
standby 1 preempt
7 Replies 7
Reza Sharifi
That is the correct behavior.  If you only have an SVI without the layer-2 vlan the SVI will not come up until you create the layer-2 vlan.  In order for the layer-2 vlan to come up, you need to add a physical port to that vlan.
cadet alain
hi,
this is a normal behaviour as for a svi to be up the vlan must exist and there must be one port in this vlan and this  port must be in the connected state. the waiting time you experience is due to spanning-tree convergence.
regards.
alain.
hi! thanks, i did create the vlan using the command below. but when i do a show run i did not see the (vlan 18 name mgt 18) portion, i can only see the interface below. When i do a show vlan, vlan 18 is there. Is that normal in 3560 switch? i can see all this info in 4506 sw. Thx.
interface Vlan18
standby 1 preempt
vlan 18
name mgt 18
Whether VTP is running on your device?
If VTP mode is in client then you wont see vlans in show run. If the device running VTP in Transparent then you will see.
This is because in client mode, vlan.dat file will be in server. Whereas in client, vlan.dat file is localized to a switch.
Hope this answers your questions.
Cheers
Somu
Rate helpful posts
Yes correct,u canot see the vlan information in sh runn unless u configure VTP server or transparent mode,then only
the SW will have the VLAN.dat in its local databse.pls note the VLAN.dat will be in flash not in NVRAM.
thx,
shehin.pm
hi! does the vtp domain thing matters in this case? I've changed it to transaprent mode, and the vlan xxx command is displayed when i do a sh run.
But, when i do a show standby, it always says that active and standby router is unknown. Thanks.
Vlan19 - Group 1
  State is Init (interface down)
    199 state changes, last state change 20:53:09
  Virtual IP address is 10.18.9.1
  Active virtual MAC address is unknown
    Local virtual MAC address is 0000.0c02.ac11 (v1 default)
  Hello time 3 sec, hold time 10 sec
  Preemption enabled
  Active router is unknown
  Standby router is unknown
  Priority 120 (configured 120)
  Group name is "hsrp-Vl19-1" (default) Vlan12 - Group 1
  Preemption enabled
This is because the the SVI is down. If the SVI interface is up in your case you will see the Active router is local and the standby router is unknown.
The VTP mode makes no difference from a functional point of view if we're just talking about HSRP, but in VTP transparent you will be able to see the vlans in the running conf, in client you will have to do a sh vlan.
Adam
