HSRP Learn state
lquin1978
Reading up on HSRP and I saw the following  on the Cisco.com website:
Learn - The router has not determined the virtual IP address and has                     not yet seen an authenticated hello message from the active router. In this                     state, the router still waits to hear from the active router.
So I read the above statment and wondered why would the router not have determined the virtual IP address? as isnt this part of the basic config?  but then I read the following:
Learn parameters—This action is taken when an authenticated                     message is received from the active router. If the virtual IP address for this                     group is not manually configured, the virtual IP address can be learned from                     the message. The router can learn hello time and hold time values from the                     message.
How can HSRP be configured without manually setting the virtual IP??
Thanks in advance
Rolf Fischer
Level 9
Level 9
you can configure a HSRP interface like this:
interface Vlan1
ip address 192.168.1.3 255.255.255.0
standby 1 ip
The virtual IP is advertised in the HSRP Hellos , so if another router on the segment has a virtual IP configured, it can be learned trough received hellos.
Vlan1 - Group 1
State is Standby
1 state change, last state change 00:07:02
Virtual IP address is 192.168.1.1 (learnt)
Active virtual MAC address is 0000.0c07.ac01
Local virtual MAC address is 0000.0c07.ac01 (v1 default)
Hello time 3 sec, hold time 10 sec
Next hello sent in 0.912 secs
Preemption disabled
Active router is 192.168.1.2, priority 100 (expires in 9.864 sec)
Standby router is local
Priority 90 (configured 90)
IP redundancy name is "hsrp-Vl1-1" (default)
Rolf
Useful link: RFC 2281 - Cisco Hot Standby Router Protocol (HSRP)
Rolf Fischer
Level 9
Level 9
interface Vlan1
standby 1 ip
Vlan1 - Group 1
State is Standby
Preemption disabled
Rolf
