HSRP problem
Arup Dutta
Hi All,
         I want to run HSRP into my network.i am using two 4503 switch one is main and another one is standby. i configured VLAN into my switch and its running, now i want to configure HSRP. my configure is attach with this mail and
my main switch gi2/22 is connect backup switch gi2/22 and all user is connect to both switch as like HSRP network.
i can use  Standby ip
10.0.1.252 (vlan-1)
10.0.2.252 (vlan-2)
10.0.3.252 (vlan-3)
10.0.4.252 (vlan-4)
10.0.6.252 (vlan-6).....so on
please help me.
Arup
Latchum Naidu
Hi Arup,
You can configure HSRP between your L3 switches.
Do the config like below and see.
Please take the necessary IP's as your choice.
And make sure the VLAN should march on both switches.
******switch1********
#Vlan 4
#ip address 10.0.4.252  255.255.254.0
#standby 1 ip 10.0.4.251
#standby 1 priority 110
#standby 1 preempt
#interface GigabitEthernet 2/22
Description: Connected to Standby
switchport mode access
switchport access vlan 4
******switch2*****
#Vlan 4
#ip address 10.0.4.253 255.255.254.0
#standby 1 priority 90
Description: Connected to Primary
You will need to set up a trunk between the two switches and allow vlan 4 to pass over the trunk.
Please rate if this helped you...
Naidu.
Hi Naidu,
Thank you for your reply.but i am little bit confuse about
configuration between L3 connectivity.
I hope Both L3 switch port that is connect to each other should trunk port
Arup
On Fri, Feb 4, 2011 at 1:52 PM, naiduccnp <
Hi Arup,
You can do the config like which i gave in my post.
I hope Both L3 switch port that is connect to each other should trunk port?
Yes, that is what i told in my post.
Please rate the helped posts....
Naidu.
