HSRP Problem
emilio1973
Level 4
Level 4
Hi all,
I can't see the standby router. This is the config in main router
FUE_COM_RT01#show standby brief
                     P indicates configured to preempt.
Interface   Grp  Pri P State   Active          Standby         Virtual IP
Gi0/1.2501  1    100 P Active  local           unknown         10.5.203.1
Gi0/1.2504  2    100 P Active  local           unknown         10.5.204.1
FUE_COM_RT01#sh run int gigabitEthernet 0/1.2501
Building configuration...
Current configuration : 306 bytes
interface GigabitEthernet0/1.2501
 description "Interface LAN Datos"
 encapsulation dot1Q 2501 native
 ip address 10.5.203.2 255.255.255.0
 ip helper-address 10.7.3.97
 ip helper-address 10.7.3.110
 standby 1 ip 10.5.203.1
 standby 1 preempt
 no ip route-cache
 service-policy input MARCADO_ENTRADA
end
And backup router:
FUE_COM_RT02#sh run int vlan 2501
Current configuration : 251 bytes
interface Vlan2501
 description Conexion ---Lan Datos---
 ip address 10.5.203.3 255.255.255.0
 standby 1 priority 95
 standby 1 preempt
 ip tcp adjust-mss 1452
vlan 2501
 name LAN_DATOS
interface FastEthernet1
 switchport mode trunk
 no ip address
 duplex full
 speed 100
And this is the config on switch that connect both routers
FUE_COM_SW01#sh run int Fa1/0/47
Current configuration : 390 bytes
interface FastEthernet1/0/47
 description FUE_COM_RT01
 switchport access vlan 2501
 switchport trunk native vlan 2501
 switchport trunk allowed vlan 2501,2504,2506,2510,2511
 speed 100
 duplex full
 storm-control broadcast level 10.00
 spanning-tree portfast
 spanning-tree bpduguard enable
end
FUE_COM_SW01#sh run int Fa1/0/33
Current configuration : 274 bytes
interface FastEthernet1/0/33
 description FUE_COM_RT02
 speed 100
 duplex full
end
FUE_COM_SW01#
Jon Marshall
Either -
1) remove the "native" keyword from your "encapsulation dot1q 2501" line on your primary router
or
2) add this to your switch trunk link -
"switchport trunk native vlan 2501"
Jon
Hi Jon, Thanks for your help. I think that modify the trunk implies a loss of service for a few seconds. I'll do in other moment. I'll keep you update.
