HSRP, routing issue
tomtom2211
i have a strange issue with an HSRP Setup.
I  have two (S1+S2) 3560 as Core/Distribution Layer. Inter-vlan routing are  enabled on both Switches. S1 and S2 are connected with an etherchannel  over four fibre ports. S3 -S5 are the (L2) access layer.
Gi0/1 on S1 and S2 are L3 ports, connect to a Linux Firewall.
HSRP is enabled, S1 is the active router and the STP root bridge.
But, my monitoring via cacti show me, that the Gi0/1 on S2 is active, too! But it should not be active? Only if S1 fails, should S2 the active switch.
A client from the access ports on S3 - 5 gets traffic from the internet via Gi0/1 from S2. Gi0/1 on S1 is active too, but will send mostly traffic to the internet.
Why is S2 active and why route it traffic from the internet to the client?
kind regards
15 Replies 15
Thomas
I am glad that you have found the solution to your problem and that our discussion was helpful. It has been an interesting discussion and took us a while to get a correct understanding of the problem. Thank you for using the rating system to mark the question as answered (and thanks for the points). It makes the forum more useful when people can read about a problem (especially a problem as unusual as this one) and can know that a solution was found. Your marking has contributed to this process.
Rick
Rick
