hsrp with sub-interface
ney25
Level 2
Level 2
some doubt about the HSRP configuration for the sub-interface, wish netpro can enlighten me. thank you in advance.
R1 :
interface Vlan10
description yahoo
ip address 192.20.137.253 255.255.255.0 secondary
ip address 192.10.3.253 255.255.255.0
standby 10 ip 192.10.3.254
standby 10 priority 110
standby 10 preempt
standby 20 ip 192.20.137.254
standby 20 priority 105
standby 20 preempt
Vl10 10 110 P Active local 192.10.3.252 192.10.3.254
Vl10 20 105 P Standby 192.10.3.252 local 192.20.137.254
R2:
interface Vlan10
description yahoo
ip address 192.20.137.252 255.255.255.0 secondary
ip address 192.10.3.252 255.255.255.0
standby 10 priority 105
standby 10 preempt
standby 20 priority 110
standby 20 preempt
Vl10 10 105 P Standby 192.10.3.253 local 192.10.3.254
Vl10 20 110 P Active local 192.10.3.253 192.20.137.254
thanks
Richard Burts
Jack
Perhaps we need some clarification: the question that you ask is about subinterface but the configuration that you give is not subinterface but is secondary addressing.
HSRP supports secondary addressing without needing a second HSRP group. In defining the shared address you can specify the optional parameter secondary to indicate to HSRP that this is a secondary address range. I am not sure whether the config that you give works, but what I have usually seen is the secondary address specified in the same group as the primary.
Rick
Rick
Hi Rick,
sorry for the typo, yes you are right i was asking the secondary interface.
ok , so which mean if i have secondary interface whereby i need not to put the secondary standby 20 ? for instance, standby 10 and standby 20 ( for secondary interface ) ?
thanks a lot man,
regards,
Jack
