HTTPS LB on Cisco6509
mohammedrafiq
Level 6
Level 6
We have a requirement to perform some https load balancing on 6509. Can Cisco 6509 perform IOS LB for https ? or does it need any special module.
Please note , we do not have any ACE module installed in switch.
Bilal Nawaz
You can use IOS SLB but this solution is not as intelligent as a real LB is.
Click here for link to configuration examples.
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
mvsheik123
Level 11
Level 11
Never tried this but see the attached helps. Try the command with 'https'.
http://www.cisco.com/c/en/us/support/docs/interfaces-modules/content-switching-module/15055-ios-slb.html
hth
MS
Looks like 6509 only do http in IOS , not https.
"""IOS SLB supports Hypertext Transfer Protocol (HTTP) probes, ping probes, and Wireless Session Protocol (WSP) probes."""""
Bilal Nawaz
