I am comparing the configs of two 3850 switch stacks that I have.  On one, the running config shows the following:
no hw-switch switch 1 logging onboard counter
no hw-switch switch 1 logging onboard environment
hw-switch switch 1 logging onboard message
no hw-switch switch 1 logging onboard poe
no hw-switch switch 1 logging onboard temperature
no hw-switch switch 1 logging onboard voltage
The other switch stack shows none of these in the running config.  Does that mean that they are not configured?  At a minimum, I would like to make sure these are at default settings, but I can't seem to locate what those are.  Ideally, what I'd really like to do is make these lines disappear completely from my running config.  Is that possible?
I don't remember any of these initially being in the config for this switch stack, until one day the "hw-switch switch 1 logging onboard message" appeared.  As I played with trying to get rid of it, all the other lines then appeared.  I've been able to toggle them one way or the other, but I can't get rid of them.  Even when I did a "copy start run", they still remain.  Can anyone provide some insight?
Thanks.
