HWIC-2FE + Cisco 2821 compatibility
wayfaring
HWIC-2FE is not working on a Cisco 2821. All lights come on at boot and stay on, never shows up in interfaces or config, tried different slots and removed other cards.  Can this document be interpreted to mean my IOS version should be OK? -
http://www.cisco.com/c/en/us/products/collateral/routers/2800-series-integrated-services-routers-isr/product_data_sheet0900aecd80581fe6.html
related posts:
https://supportforums.cisco.com/discussion/10992316/does-wic-2t-hwic-2fe-work-together-2821
https://supportforums.cisco.com/discussion/10729541/hwic-1fe-and-ios-version-compatibility-2811
https://supportforums.cisco.com/discussion/10995216/cisco-2851-isr-not-recognizing-2-port-fe-hwic
http://networking.ittoolbox.com/groups/technical-functional/cisco-other-l/cisco-2800-does-not-detect-card-hwic2fe-4529117
my router -
Cisco IOS Software, 2800 Software (C2800NM-ADVENTERPRISEK9-M), Version 12.4(22)T, RELEASE SOFTWARE (fc1)
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
System image file is "flash:c2800nm-adventerprisek9-mz.124-22.T.bin"
during boot -
smart init is sizing iomem
  ID            MEMORY_REQ                 TYPE
0003E8          0X00473800 C2821 Mainboard
00053B          0X000C2800 2-port FE HWIC
                0X00264050 Onboard VPN
                0X000021B8 Onboard USB
0004F4          0X00016804 Virtual Private Network (VPN) Module
                0X002C29F0 public buffer pools
                0X00211000 public particle pools
TOTAL:          0X00C863FC
*Aug  5 21:21:09.695: %GT96K_FEWAN-1-UNKNOWN_WIC: slot 0, wic card has an unknown id 53B
test-2821#sh diag
  WIC Slot 0:
        2 Port FE HWIC
        WIC module not supported/disabled in this slot
        Hardware Revision        : 2.0
        Top Assy. Part Number    : 800-33018-01
        Part Number              : 73-12949-01
        Board Revision           : A0
        Deviation Number         : 0
        Fab Version              : 03
        PCB Serial Number        : FOC*
        RMA Test History         : 00
        RMA Number               : 0-0-0-0
        RMA History              : 00
        Product (FRU) Number     : HWIC-2FE
        Version Identifier       : V02
        CLEI Code                : COUIAFUCAB
        Base MAC Address         : 2c54.2db0.112b
        MAC Address block size   : 2
        Connector Type           : 01
        EEPROM format version 4
        EEPROM contents (hex):
test-2821#sh hardware
Cisco 2821 (revision 53.51) with 247808K/14336K bytes of memory.
Processor board ID FTX1
2 Gigabit Ethernet interfaces
2 Virtual Private Network (VPN) Modules
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
990864K bytes of ATA CompactFlash (Read/Write)
test-2821# sh inv
NAME: "2821 chassis", DESCR: "2821 chassis"
PID: CISCO2821         , VID: V04 , SN: FTX1
NAME: "Virtual Private Network (VPN) Module on Slot 0", DESCR: "Encryption AIM Element"
PID: AIM-VPN/SSL-2     , VID: V01, SN: FOC1
Leo Laohoo
Try upgrading the IOS router to another "T" train.
Leo Laohoo
