I am not able to ping device attached to the opposite interface of the router
BorisMGMG
Community Member
Hi Guys
When I am trying to ping the address 10.30.0.84 of laptop attached to Gi0/1 from the laptop attached to interface to interface gi0/2 - not able
Able to ping 172.22.0.1 and 10.30.0.72 interfaces
What is the problem ? Configuration is attached
interface GigabitEthernet0/1
 ip address 10.30.0.72 255.255.255.224
 no ip route-cache
 duplex auto
 speed auto
 media-type rj45
 no negotiation auto
 no mop enabled
interface GigabitEthernet0/2
 ip address 172.22.0.1 255.255.255.0
 no ip route-cache
 duplex auto
 speed auto
 media-type rj45
 no negotiation auto
interface GigabitEthernet0/3
 no ip address
 no ip route-cache
 shutdown
 duplex auto
 speed auto
 media-type rj45
 no negotiation auto
ip default-gateway 10.30.0.65
ip route 0.0.0.0 0.0.0.0 10.30.0.65
ip route 172.22.0.0 255.255.255.0 GigabitEthernet0/1 10.30.0.65
ip http server
ip http authentication local
ip http secure-server
Mike
6 Replies 6
saif musa
Level 9
Level 9
Delete this row
and upload the result from show ip route please...
Thank you for the respond
Here is the new configuration:
 no ip route-cache
 duplex auto
 speed auto
 media-type rj45
 no negotiation auto
 no mop enabled
 no ip route-cache
 duplex auto
 speed auto
 media-type rj45
 no negotiation auto
 no ip address
 no ip route-cache
 shutdown
 duplex auto
 speed auto
 media-type rj45
 no negotiation auto
ip http server
logging alarm informational
control-plane
gatekeeper
 shutdown
line con 0
 stopbits 1
line aux 0
 stopbits 1
line vty 0 4
 privilege level 15
 password ciscotech12
 login local
 transport input telnet ssh
I
SHOW IP ROUTE RESULTS
Default gateway is not set
Host               Gateway           Last Use    Total Uses  Interface
ICMP redirect cache is empty
Laptops attached to G0/1 and to G0/2 still not able to ping each other after the chages you suggested
Thank you very much - here is show version results:
#show version
Cisco IOS Software, 7200 Software (C7200-ADVENTERPRISEK9-M), Version 12.4(11)T1, RELEASE SOFTWARE (fc5)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Thu 25-Jan-07 19:57 by prod_rel_team
ROM: System Bootstrap, Version 12.3(4r)T3, RELEASE SOFTWARE (fc1)
BOOTLDR: Cisco IOS Software, 7200 Software (C7200-BOOT-M), Version 12.4(12), RELEASE SOFTWARE (fc1)
RichmondHill2B uptime is 1 minute
System image file is "disk2:c7200-adventerprisek9-mz.124-11.T1.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 7206VXR (NPE-G1) processor (revision B) with 983040K/65536K bytes of memory.
Processor board ID 31780761
SB-1 CPU at 700MHz, Implementation 1025, Rev 0.2, 512KB L2 Cache
6 slot VXR midplane, Version 2.7
Last reset from power-on
PCI bus mb1 (Slots 1, 3 and 5) has a capacity of 600 bandwidth points.
Current configuration on bus mb1 has a total of 0 bandwidth points.
This configuration is within the PCI bus capacity and is supported.
PCI bus mb2 (Slots 2, 4 and 6) has a capacity of 600 bandwidth points.
Current configuration on bus mb2 has a total of 0 bandwidth points.
Please refer to the following document "Cisco 7200 Series Port Adaptor
Hardware Configuration Guidelines" on Cisco.com <http://www.cisco.com>
for c7200 bandwidth points oversubscription and usage guidelines.
3 Gigabit Ethernet interfaces
509K bytes of NVRAM.
62720K bytes of ATA PCMCIA card at slot 2 (Sector size 512 bytes).
16384K bytes of Flash internal SIMM (Sector size 256K).
Yes laptops have gateways as a interface IPs where they are attached to.
Thank you
Mike
Did you identify the gateway for each laptop ?
and please upload the result from show version command inside your router and try to copy and paste all the result not just part of it.
