12-12-2023 09:20 AM
Even after completing all the modules, as well as the final exam with more than 70%
I'm not able to get the badge.
It shows in progress, but all the courses are 100% completed.
Whom should I contanct and report this issue?
12-12-2023 09:29 AM
what badges , if you complete the cource and take exam only you get badges, if you pass the exam, they will email you with 48hours
12-12-2023 08:44 PM
Networking basics course completion badge... I did pass the final exam, but still it I am not getting it.
12-13-2023 03:28 AM - edited 12-13-2023 03:29 AM
Hello Hashx,
Congatulations..!! on completing the Networking Basics course from skillforAll. It may take up to 48 hours...to receive the email....If you meet all the requiremnts for eligibility criteria. if you don't receive an e-mail within 48 hours...use the below link to contact skillforall support:
https://www6.nohold.net/SkillsforAll/ukp.aspx?pid=2&login=1&utm_source=prelogin&donelr=1
Best regards
******* If This Helps, Please Rate *******
12-14-2023 08:29 PM
It has been more than 48 hours but still I didnt recieve any email... I tried using skillsforall support but there is no solution for not recieving mail
12-14-2023 09:03 PM
Since...You didn't receive any e-mail even after 48 hours... Please cross check following things:
The above criteria you must meet... then only you will eligible to receive the badge....
If you are meeting the above criteria...then perform the following steps...
Best regards
I
12-14-2023 10:23 PM
The couse is 100% completed... My profile page is updated.
I am not getting the badge in my latest achievement section, thats why I was waiting for mail. I did not get my badge.
12-14-2023 10:39 PM - edited 12-14-2023 10:41 PM
well done... Please...perform the following setps to accept the badge...
12-14-2023 11:11 PM
There is no Networking basic badge under Latest achievements section... that is the problem... I did not get the badge... It is not there in latest achievement
12-14-2023 11:16 PM
It seems your side is well...
Under Achievements --> click on show all and veriy your badge is there or not ?
Best regards
12-14-2023 11:47 PM - edited 12-14-2023 11:47 PM
Under Achievements --> show all section...You should find your badge...
If you didn't find your badge...have patience...hope you will receive your badge soon...it is for sure...i did almost more than 10 courses from skillforall...sometimes...it may takes time ....Sure you will get it.
Best regards
