I am unable to ping to outside network.
OneZ12345
Hi guys eventually i configured Inter-VLAN using layer 3 switch but I seem to not be able to find the issue why my pcs is able to ping to the ISP router but not outside of the network (Internet). I am just a beginner and don't really know how to troubleshoot this issue. I did try to put Ip route address but it is still not able to send packets.
You need NAT
MHM
This is my ISP_router configuration:
Current configuration : 1872 bytes
version 15.4
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname ISP=Router
ip dhcp excluded-address 172.16.0.1 172.16.0.10
ip dhcp pool LAN
network 172.16.0.0 255.255.255.0
default-router 172.16.0.1
dns-server 202.21.1.11
domain-name SRWE.COM
no ip cef
ipv6 unicast-routing
no ipv6 cef
ip domain-name customer.isp.net
spanning-tree mode pvst
interface GigabitEthernet0/0/0
description ToInternet
ip address dhcp
ip nat outside
duplex auto
speed auto
ipv6 address 2001:DB9:0:2::2/64
interface GigabitEthernet0/0/1
description ToLan
ip address 172.16.0.1 255.255.255.0
ip nat inside
duplex auto
speed auto
ipv6 address 2001:DB8::1/64
interface GigabitEthernet0/0/1.10
encapsulation dot1Q 10
ip address 172.16.10.1 255.255.255.0
interface GigabitEthernet0/0/1.20
encapsulation dot1Q 20
ip address 172.16.20.1 255.255.255.0
interface GigabitEthernet0/0/1.30
encapsulation dot1Q 30
ip address 172.16.30.1 255.255.255.0
interface GigabitEthernet0/0/1.40
encapsulation dot1Q 40
ip address 172.16.40.1 255.255.255.0
interface GigabitEthernet0/0/1.50
encapsulation dot1Q 50
ip address 172.16.50.1 255.255.255.0
interface GigabitEthernet0/0/2
no ip address
duplex auto
speed auto
shutdown
interface Vlan1
no ip address
shutdown
ip nat inside source list TOINTERNET interface GigabitEthernet0/0/0 overload
ip classless
ip route 172.16.0.0 255.240.0.0 GigabitEthernet0/0/1
ip flow-export version 9
ipv6 route ::/0 2001:DB9:0:2::1
ipv6 route 2001:DB8::/32 2001:DB8::11
ipv6 route 2001:DB8::/32 2001:DB8::12
ip access-list standard TOINTERNET
deny any
permit 0.0.0.0 255.255.255.0
permit 172.16.0.0 0.15.255.255
line con 0
exec-timeout 0 0
line aux 0
line vty 0 4
login
end
This is my Layer 3 switch configuration:
Building configuration...
Current configuration : 2618 bytes
version 16.3.2
hostname Switch
ip dhcp pool VLAN10-DHCP
network 172.16.10.0 255.255.255.0
default-router 172.16.10.1
ip dhcp pool VLAN20-DHCP
network 172.16.20.0 255.255.255.0
default-router 172.16.20.1
ip dhcp pool VLAN30-DHCP
network 172.16.30.0 255.255.255.0
default-router 172.16.30.1
ip dhcp pool VLAN40-DHCP
network 172.16.40.0 255.255.255.0
default-router 172.16.40.1
ip dhcp pool VLAN50-DHCP
network 172.16.50.0 255.255.255.0
default-router 172.16.50.1
ip cef
ip routing
no ipv6 cef
interface GigabitEthernet1/0/1
switchport mode trunk
interface GigabitEthernet1/0/2
switchport trunk allowed vlan 10,20,30,40,50
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
interface GigabitEthernet1/1/1
interface GigabitEthernet1/1/2
interface GigabitEthernet1/1/3
interface GigabitEthernet1/1/4
interface Vlan1
no ip address
shutdown
interface Vlan10
mac-address 00e0.f90a.1701
ip helper-address 172.16.0.1
interface Vlan20
mac-address 00e0.f90a.1702
interface Vlan30
mac-address 00e0.f90a.1703
interface Vlan40
mac-address 00e0.f90a.1704
interface Vlan50
mac-address 00e0.f90a.1705
ip classless
ip route 0.0.0.0 0.0.0.0 162.21.1.11
line con 0
line aux 0
line vty 0 4
login
end
deny any <- this need to remove
permit 0.0.0.0 255.255.255.0 <- this also need to remove not need it
permit 172.16.0.0 0.15.255.255 <- keep this
MHM
