I Have An Issue Regarding IoT in Packet Tracer 7.1.1
Yair Levi
Hello, I have an IoT server configured on one of my packet tracer files, and for some reason when I try to create
conditions at my IoT Registration server I click "OK" but the condition I made doesn't show up in front of me, as if it is invisible. Can anyone tell me how to fix this?
9 Replies 9
post your Packet Tracer project file (.pkt). ZIP it first otherwise the system won't let you upload it...
go in the Philadelphia cloud and try to make a condition in the registration server
Did you post the zipped project file ? I don't see it attached anywhere...
luis_cordova
Hi @Yair Lev,
To rule out that it is a bug of the version, you could install the latest version of PacketTracer (7.2.1) and open with that version your exercise.
cg338
I have the same issue.
Hi @cg338
Compress your exercise (winzip) and attach it to check it out.
Here is my file. Thanks.
stivtahiri
Ninja0k
Hey... I had the same problem, but my solution was simple. I deleted the IoT server—basically, I did Ctrl+C and Ctrl+V and then got rid of the old server. The problem was the server itself.
