I HAVE PROBLEM WITH SWITCH 3650 PBR
I am trying to enable policy based routing on a new 3560x switch.
The device has the following code  CAT3K_CAA-UNIVERSALK9-M and the IPSERVICES license
I can create the route map in global config mode but when I try to enable pbr under the required interface SVI the commands are not there.
therefore I am typing   ip policy route-map "name"  the word policy does not show up in the interface config mode.
Any assitance would be greatly appreciated.
ghostinthenet
Level 7
Level 7
What version of IOS XE are you running? 3.3 or 3.6? PBR requires that you be running at least 3.6 on the 3650.
Also, make sure you're running the Advanced SDM template. The VLAN SDM template has no PBR capability.
Jody Lemoine, Network Architect
CCIE 41436, MTCRE, MTCINE, MTCIPv6E
tishco networks, Virtually Everywhere
(905) 378-1134, jody.lemoine@tishco.ca
Hello Jody
 The device has the following code WS-C3650-24TS 03.03.03SE cat3k_caa-universalk9, proceed to upgrade to version 3.6 and with that I hope to join my SVI vlan command to PBR. thanks for your help I will be informing you about the progress.
