I tried to copy running config into startup config with "WRITE" and "COPY RUN START" commands on "CISCO 2960X Switch" but facing Issue.
I tried to copy running config into startup config with "WRITE" and "COPY RUN START" commands on "CISCO 2960X Switch" but facing following issue displayed in image. I dont have enough knowledge to play with Flash Memory. I will appreciate your help.
Leo Laohoo
Post the complete output to the following commands:
sh boot
